Y won't this cd player work
Yakumo.8
N/A
//content.invisioncic.com/y282845/emoticons/help.gif.cee8f684da1ba626487a8bc51152e1ec.gif i drive a Honda Accord 98 Sedan V6... i have all aftermarket audio in there and one day my deck just stopped playing while i was listening to music... heres the funny part all the speaker wires are secure and good... all fuses are good and connected... all wires going to the deck are fine... why won't it work?
thanks to anyone that replies
BTW the HU is a Jenson CM-720K
sidequestion... how far apart from each other do the ground wires and remote wires have to be in order to not make yer engine make that alternator whining sound?
Well your distance with the ground thing does not have to do with the remote. It usually comes from the quality of the ground, not how close it is.
as for the CD player. Is it turing on at all????? If not then recheck you fuse. If they are all good then pull you HU and check to make sure you are getting 12 volts to your power wire. If you are then check your ground again and make a new one. If that does not fix it then BUY a new one. Sorry.
check the fuses in the fuse box in ur driver's side i believe. but it just seems your cd player gave up, Jenson? dat could be the answer
anyways, if the cdplayer doesn't turn on at all but everything else in ur car works then maybe ur cd player might be done.
Yakumo.8
Yakumo.8
N/A
Matador
BP1Fanatic
    Apr 17, 2025
BP1Fanatic
    Apr 17, 2025
