Xtant 403a balanced line inputs/input gains
sungwei
lkj
Just discovered that my xtant 403a has a jumper switch that turns the input signal into a balanced signal. This effectively boosts the input to 17 volts according to the manual! In addition to that you can increase the input gain. These two features combined act in the same manner as a line driver and gets rid of any ground noise/excess noise. My sound is so clean after discovering these two features. I'm so happy. I'm gonna do a write up on this amp in the review section after using it a bit more. Wanna see if it can hold up with my sub wired parallel at 1 ohm load. If it can do this without frying (which it's been fine so far) I'll be thoroughly impressed. Any other amps out there that have this feature? I found it quite awesome.
  • Locked
COMPLETED Xtant XIS 2.4
Also looking for the crossovers
3K
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
9
sungwei
sungwei
lkj
sungwei
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
