Featured WTS: SKAR AUDIO DUAL 12" 2400W SDR COMPLETE BASS PKG LOADED SUB BOX - AMP - WIRE KIT
Abt Electronics
CarAudio.com Newbie
Product Description
Skar Audio created this custom loaded enclosure package to deliver powerful, deep, and tight bass in an all-in-one competition-grade system. This package features two, 12-inch, dual 4-ohm, Skar Audio SDR Series subwoofers, which are pre-loaded and wired up inside of a custom dual 12" ported enclosure. Next, we pair the loaded enclosure of this package with the Skar Audio RP-1200.1D Class D mono-block amplifier, the perfect amplifier to power your new system and matched for perfect compatibility and power handling with the included subwoofers. Finally, we include a premium Skar Audio 4 Gauge OFC premium amplifier wiring kit to install your new system, making installation hassle free.
The Skar Audio SDR series of subwoofers were designed to deliver hard hitting, low spectrum sound. Featuring a high flux ferrite motor, these versatile 12-inch woofers are conservatively rated at 1,200 watts max power each. When looking for a system that delivers low end frequencies with authority, look no further. This is the perfect solution for a daily driver that can handle whatever is thrown at it, offering unmatched reliability and sound quality. The enclosure housing the subwoofers features a unique kerf middle port and split chamber woofer design, allowing for extreme levels of bass output. Furthermore, the enclosure is finished in premium grade black carpet for a sleek appearance and features the Skar Audio logo in white on the top surface of the box.
This package was put together by our installation experts to ensure compatibility and allow for an easy installation. We take the guess work out of pairing the components of your system up, and make it easy to get the bass you've always wanted in your ride.
This Package Includes The Following Items
  • 1x Skar Audio SDR-2X12D4 Dual 12" SDR Series 2,400 Watt Max Power Loaded Ported Subwoofer Enclosure
  • 1x Skar Audio RP-1200.1D Monoblock 1200 Watt Class D Subwoofer Amplifier
  • 1x Skar Audio SKAR4ANL-OFC 4 Gauge OFC Complete Amplifier Wiring Kit with 120 Amp ANL Fuse Included
Compatible with The Following Vehicles
  • Universal Fit - Check Enclosure Dimensions to Ensure a Proper Fit
*The dual 4 ohm subwoofers included in this package are pre-wired and loaded into the subwoofer enclosure at a 1-ohm final load to ensure an easy and hassle free installation when paired with the included amplifier.
Skar Audio SDR-12 D4 Subwoofer Specifications
  • Includes (2) Subwoofers Pre-Loaded Into Subwoofer Enclosure
  • Skar Audio SDR-12 D4 - 12" Dual 4 Ohm Subwoofers
  • Coil Configuration: Dual 4 Ohm
  • Peak Power: 2,400 Watts (pair) | 1,200 Watts (each)
  • RMS Power: 1,200 Watts (pair) | 600 Watts (each)
  • Frequency Response: 22 - 300 Hz
  • 2.5" High Temperature Copper Voice Coil
  • Competition Grade Pressed Paper Cone
  • High Roll Foam Surround
  • Advanced Airflow Cooling Design
  • Motor Weight: 97 Oz
  • Sensitivity (spl): 84.7 dB
  • Fs: 32 Hz
  • Bl: 10.45 n/a
  • Qts: 0.50
  • Qes: 0.57
  • Qms: 4.21
  • Cms: 0.13 mm/N
  • Vas: 43.4 L
  • Xmax: 13.5 mm (one-way)
Skar Audio RP-1200.1D Amplifier Specifications
  • Skar Audio RP-1200.1D Class D Monoblock Car Subwoofer Amplifier
  • 4 Way Protection Circuitry: Thermal, Voltage, Speaker, DC
  • Max Power at 1 Ohms: 1,600 Watts x 1 Channel (14.4v)
  • RMS Power at 1 Ohms: 1,200 Watts x 1 Channel (14.4v)
  • RMS Power at 2 Ohm: 800 Watts x 1 Channel (14.4v)
  • RMS Power at 4 Ohms: 500 Watts x 1 Channel (14.4v)
  • MOSFET Power Supply
  • Soft Turn on Circuit
  • Tri-Mode Capable / Bridgeable
  • Frequency Response: 20 Hz ~ 250 Hz
  • Signal to Noise Ratio: 85 dB
  • Damping Factor: 200<
  • Low Pass Filter (Variable): 50 Hz ~ 220 Hz
  • Subsonic Filter: 0 ~ 50 Hz
  • Remote Bass Knob & Wire Included
  • 4 Gauge Power and Ground Terminals
  • Working Voltage: 8.5V - 14.4V
  • Fuse Rating: 100 Amp
  • Dimensions: 11.875" (Length) x 6.1875" (Width) x 2.25" (Height)
Dual 12" Ported Enclosure Specifications
  • Dual 12-Inch Vented (Ported) Subwoofer Enclosure
  • Custom Engineered Skar Audio Enclosure specifically Designed for use with the Skar Audio SDR-12 D4 (x2) Subwoofers
  • "Wedge" Style Enclosure with Vented Design allows for Extreme Low End Bass Output Levels and Responsiveness
  • Wood Thickness & Material: 5/8" MDF
  • Front Baffle Thickness: 1.25"
    • (Double Baffle - Countersunk Design for a Smooth, Flush, Subwoofer Appearance)
  • Finish: Black Colored Carpet with Skar Audio logo in White on Top of Enclosure
  • Premium Push Terminals Located on Left Side of Enclosure (one terminal cup only - woofers are wired internally to reach a 1-ohm final load)
  • Internal Air Space of Enclosure: 4.00 ft³
  • Tuning Frequency of Enclosure: 32 Hz
  • Box Outer Dimensions:
    • Width: 37.875"
    • Depth #1: 16.75" (Top Depth)
    • Depth #2: 18.75" (Bottom Depth)
    • Height: 14.25"
Skar Audio SKAR4ANL-OFC 4 Gauge OFC Amplifier Wiring Kit Specifications
  • Skar Audio Model: SKAR4ANL-OFC
  • 4 Gauge Complete OFC Amplifier Installation Kit with ANL Style In-Line Fuse Holder
  • Everything You Need to Install & Wire Up Your Amplifier
  • Premium 4 Gauge Oxygen Free Copper (OFC) Wire for Maximum Current/Power Transfer
  • 17 ft. of 4 AWG OFC Matte Blue Ultra Flexible Power Cable
  • 3 ft. of 4 AWG OFC Matte White Ultra Flexible Ground Cable
  • 16 ft. of Blue Remote Turn-on Wire
  • 17 ft RCA 2-Channel Blue Twisted Pair Shielded Interconnect Cable
  • 20 ft. of 16 Gauge Matte Blue Ultra Flexible Speaker Wire
  • High Current ANL Style Fuse Holder
  • 120 Amp ANL Fuse Included
  • 3 Ft Black Flex Wire Loom
  • Ring Terminals
  • Ground Terminals
  • Vinyl Cable Ties Included
CONTACT US VIA EMAIL FOR INQUIRY: INFO@ABTELECTRONICCOMPANY.COM
Product Description
  • Fs: 32 Hz
  • Bl: 10.45 n/a
  • Qts: 0.50
  • Qes: 0.57
  • Qms: 4.21
  • Cms: 0.13 mm/N
  • Vas: 43.4 L
    • Width: 37.875"
    • Height: 14.25"
  • Ring Terminals
  • Ground Terminals
The Skar Audio SDR Series Dual 12" Loaded Ported Subwoofer Enclosure Package is an excellent choice if you're looking for deep, powerful bass. This system includes everything you need for installation and peak performance.
### Key Features:
1. Subwoofers:
- Skar Audio SDR-12 D4 — Each 12" subwoofer has a max power rating of 1,200 watts, delivering a peak power of 2,400 watts for the pair. With a frequency response of 22 - 300 Hz, they effectively handle low spectrum sound.
- High Roll Foam Surround and an advanced airflow design enhance durability and performance.
2. Amplifier:
- Skar Audio RP-1200.1D provides 1,200 watts RMS at 1 ohm, perfectly matched to the subwoofers. The amp features MOSFET power supply and four-way protection circuitry to ensure reliability under heavy workloads.
3. Enclosure:
- The custom-engineered ported enclosure is designed specifically for these subwoofers. It features internal air space of 4.00 ft³ and a tuning frequency of 32 Hz, promoting extreme bass output levels.
4. Wiring Kit:
- The kit includes a 4 Gauge OFC wiring complete with an ANL fuse, which is essential for maximum power transfer and safety during operation.
### Installation Tips:
  • Check Compatibility: Make sure your vehicle has the dimensions to accommodate the enclosure.
  • Wiring: Follow the wiring diagram provided to connect the amplifier to the subwoofers correctly. Remember that they are pre-wired for a 1-ohm final load.
  • Power Supply: Ensure your vehicle's electrical system can handle the demands of the amplifier.
### Additional Considerations:
  • Space Requirement: Ensure you have adequate space for the enclosure. The outer dimensions are approximately 37.875" W x 14.25" H x 18.75" D.
  • Power Source: Inspect your vehicle's battery and alternator capacity since the amplifier will draw significant power.
If you have any further questions about compatibility, installation, or performance, feel free to ask! Other forum members may also have additional tips and insights to share.
That domain (abtelectroniccompany.com) looks to be fake and is highly likely part of a scam.
The real retail giant is Abt Electronics (using the official domain abt.com). Scammers frequently buy domains that use variations of real company names to trick people into purchasing high-end gear online.
How do you mean ?
I mean, that Abt, the real Abt, registered thier Abt.com domain name on January 11th, 2000.
You registered your scammer domain on June 6th, 2026!
May the fleas of a thousand camels infest your a$$ crack and armpits on the hottest day of the year!
That's really what I mean.
Abt Electronics
CarAudio.com Newbie
Abt Electronics
California
Doxquzme
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
