would i end up making a poorly tuned bandpass box
nismboy6986
the **** technician
I had this idea to have my box facing forward and build a 4 walls out of mdf/fiberglass around the sub and ports to "seal" off the bass from the trunk so as far as the sub is concerned it is actually in the back of the interior instead of in the middle (i read steve brown's section on "bass loading" in car audio and electronics mag) but i was wondering would these walls actually act as a port and i would technically end up with a poorly tuned bandpass box since a bandpass box is basically just a sub in a sealed enclosure firing through a port. I was also wondering would it be necissary to seal the factory speaker holes along with other holes in the rear deck to prevent the bass from leaking back into the trunk. Also is it true that the bass actually gets magnified by it bouncing off the trunk lid thus making it louder or is that only true for it bouncing off the glass in a hatchback/suv since i'm installing in a sedan.
  • Locked
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
  • Locked
If you’re going to spend that kind of money, you should be looking at Beryllium domes too. Like the ScanSpeak Illuminator D3004/6040-00 Beryllium...
3K
Have you had the chance to make a comparison of sound quality and performance between Audiofrog GB15 tweeters and other brands like Morel Supremo...
In grade school we discovered some learning issues and by the following semester she was invited to join an advanced math program. Did robotics in...
7
  • Locked
I have some nice high end 6x9s if your still looking
4
3K
nismboy6986
the **** technician
nismboy6986
Belhaven NC
nismboy6986
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
