would i be insane running 2400 watts @ 2 ohms to 2 12" re se's?
iamamp3pimp
Bass Heads Entertainment
13,502
Tampa FL
is that crazy?
i can get them reconed do run a dual 2 config but would i just be better off selling them and upgrading to the sx's or the xxx's?
the amps are the viper 1200.1d strapped together to produce 2.4kw @ 2 ohms. i still have a stock charging system which will be upgraded fairly soon
thanks for the input
peace
i know its somewhat possible, i met this cat that ran 1800 watts thru one with no problem, but he knew what he was doing a whole lot better than i do (not that i dont, he's just been in the biz 4 years)
but thanks for the advice. i guess ill put em on the block for sale when i get a little extra cash for sx or xxx's whichever i get
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
776
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
iamamp3pimp
iamamp3pimp
Tampa FL
iamamp3pimp
spokey9
    Jul 17, 2024
1aespinoza
    Jul 15, 2024
