BooLeaN
Somone told me that you can wire a DVC sub up this way.
If it's Dual 2 ohms, connect the + to the other coil's - and then the - to the other coil's +.
So basically like you are going to go series, but do it two times.
Then to connect to the amp, you connect all the +'s to the + on the amp and all the -'s to the - on the amp.
If it's a DVC 2 ohm woofer you get a 2 ohm load.
Is this true? So that means you can wire a DVC 2 ohm subs to 1, 2, or 4 ohms????
Thanks,
Craig G
Thanks,
Craig G
