Wiring question - need help
  • Thread starter <thumpinblazr>
  • Live activity
  • Replies 2
  • Views 2K
<thumpinblazr>
Guest
alright, i am getting 2 12" rockford HX2's and i am getting the dual 4 ohm models. I have 2 SEPERATE boxes for them. My amp is 2 channel and runs at 2 ohms stereo and 4 ohm mono. If i wire each sub with the voice coils parallel, that will give the amp 2 seperate 2 ohm signals right? now my question is this: if my amp runs at 2 ohm in STEREO, will the 2 seperate 2 ohm signals be right? i guess im not getting the whole mono and stereo idea.
Also, when i wire them parallel, i make 2 Y's and connect the +'s of the coils together and the -'s of the coils together, then put both +'s to one connection and the 2 -'s to the other? is that right? do i just twist the 2 sets together and put them to each connector?
thanks for reading, and thanks in advance for your help,
Dustin
Originally posted by :alright, i am getting 2 12" rockford HX2's and i am getting the dual 4 ohm models. I have 2 SEPERATE boxes for them. My amp is 2 channel and runs at 2 ohms stereo and 4 ohm mono. If i wire each sub with the voice coils parallel, that will give the amp 2 seperate 2 ohm signals right?
yep
yep
Stereo is two seperate channels. Mono means these two channels are combined two make one
you can do it that way
you can do this if you want.
Dustin
Hope I answered what you were after
If you're not caught on the name trend try 2 12" Volfenhag 1000 watt subs. These thing are monsters. 22 lb magnets dvc 500 watts rms. I just ordered four of these and haven't found anything close for the price. They'll hit you for @ 175 on e bay w/ shipping. If tested them against some audiobahns and fosgate and the Volfenhags ate them. They do need power, if you could give them 400 rms per channel in a larege slot port SPL box I think you'ld be impressed.
Guest
Cay_and_Cays
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
