Wiring Purchase Help
Daleon
Hi guys,
So I am about to completely redo my entire sound system in my 98 pathy and need some help figuring out how much wire and odds and ends I will need.
So far what I've got:
Replaced headunit with Kenwood z828
Ordered Boston Pro's 2way comps
Ordered snail shell for single 15"
Got a pre-order on a XXX 15" whenever they get back in stock
Crossfire tek 150.2
2nd amp will either be a Hifonics Brutus 1500 or a mtx 81000d
Plan to replace battery with a yellowtop 34/78
Do the Big 3 and possibly use a Batcap 400 or end up getting an new Alt but seems hard to find good Nissan HO alt's for Pathys.
So far I have 2 20" stinger bullet series RCA's. This should be all I need as far as RCA's right?
Next I want to replace all my speaker wire with 12ga. I will probably not replace my rear fill 6 1/2's right away and either run them off HU or leave them disconnected for now but I want to do the speaker wire all at once. So if anyone is familar with this body style SUV and done the wiring on them, how much speaker wire am I looking at? Tweets, Front 6 1/2's, Rear 6 1/2's, and wiring sub. Do I just run speaker wire from the HU to them? Do I also need some to run from amps to crossovers or anything? Was thinking 60-75 ft?
Next is power wire. I'll be replacing the weak 8ga I have now with 0/1 ga. I plan to take it to a fuse anl distro box and split out 4/8ga to amps and ground. Possibly fitting in a Batcap 400 if I do use one. Then enough left over to do Big 3. Thinking 40 ft 0ga and 10 ft 4ga and 10 ft 8ga?
Also any ideas on terminals, clamps, or y-boots? Little odds and ends that make things cleaner? I know this is alot to cover but I've never done a full blown install myself like this and I want to be ready when I do it.
Thanks
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
679
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
938
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
997
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
851
Daleon
Daleon
Atlanta, GA
Daleon
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
