wiring DVC sub
infinity1412
i already looked at the sticky and i still need help........i have 2 kicker CVR 10s, they are DVC 2 ohm, i want them wired to a 2 ohm load, do you take one coil on each sub and hook the positive to the negative? and how do you wire them, do you take just one speaker wire and hook them up? thanks in advance
mike
to obtain a 2ohm overall system load, you have to wire each sub in parallel then wire the two together in series. when you wire each sub in parallel, you obtain 1ohm for each sub. then you wire both of the subs together in series to obtain 2ohms.
infinity1412
infinity1412
ocala fl
InhumanAcura
RobGMN
    Apr 22, 2025
Doxquzme
    Apr 21, 2025
