idiot
Now that I’ve chosen which electronics and components of my future system I will be getting, it’s time that I learned how to properly connect them.
First, the amps.
I have two amplifiers that draw 50 amps a piece. Both will be placed beneath the driver’s seat, which is 5 to 10 feet from the battery (depending on the twists and turns of the wire). I intend to run one power and one ground wire through the firewall, to a pair of distribution blocks. For a 100 amp total draw that runs less than 10 feet, I assume that a 4 gauge wire will be sufficient.
Power wire
Inline Fuse (for power wire)
Inline Fuse Holder (for power wire)
Ground Wire
The power wire will connect to a fused distribution block, which will split the signal to two 8 gauge wires (two 50 amp loads). The blocks will be under the same seats as the amps, so the split signals will travel less than a foot.
Fused Power Distribution Block
The ground wire will connect to an unfused distribution block, also splitting the 4 gauge ground signal into two 8 gauge wires to connect with each amp. Again, the split signal will only travel a few inches.
Ground Distribution Block
Now, this part of the design rests on a few assumptions that I’m not sure are correct.
1) The ground should be connected directly to the negative terminal on the battery, which would reduce the possibility of alternator whine caused by bad grounding locations. Since I don’t think I want to ground inside the cabin, I would end up running the ground wire into the engine bay anyway, so I might as well ground to the battery.
2) The ground and power wires can be run side-by-side for as long as I want without any adverse effects.
Now that the hard stuff is out of the way, let’s briefly move to the head unit and speakers.
I will be using a head unit with only two pre-outs (front and rear). As such, I will need two RCA cables. I’m not sure what I should look for in a cable, but this seemed a decent price. I know that some people spend considerably more, yet others swear that there is no discernable difference in the $15 RCA’s and the $50 ones. I’d appreciate some input. But for now, these look good.
RCA Cable
Now I’m not quite sure which kind of speaker wire I should be getting (either the kind with positive and negative twisted around each other, or the kind where the positive and negative run parallel). I’ve heard that the twisted wire helps to reduce the chance of picking up noise… or something? Could someone explain this to me? I was looking 14 gauge wire (they’ll be pushing more than 180 watts… I’m not sure if 16 gauge would work), but I’m not sure which kind to get.
Also, what gauge would safely push 350-400W? I need to pick a size to fit my sub.
First, the amps.
Power wire
Ground Wire
RCA Cable
