Wiring another amp?
Jt321
Im going to add my jbl 1200 amp this week and im going to run 4 gauge wire from the battery to the distro block. Then from the distro block 4 gauge wire to the (2) amps. The jbl has a total of (3) "40" fuse & the other amp has (2) "20" fuse. My question is how big of a fuse should i place by the battery? And should i fuse the power cable from the distro block to the amps itself?
Thx -John
Another quick question, Can i tap into the existing remote turn on lead? So the remote turn on wire will be powering 2 amps? Will this cause any problems?
thx
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
639
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
896
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
8
937
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
990
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
813
Jt321
Jt321
Surprise, AZ
Mind_nl
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
