have a question.. i got 2 DVC 4ohm subs.. my 4 channel amp is not rated below 4ohm when bridged ( p400.4 ) .. so basically i want to wire each sub at 4ohms.. can i wire them off of 1 voice coil on the sub, pos and neg, keeping it 4ohm.. or does the other coil on the sub need to be wired also? every diagram i see just shows me how to wire the subs into 1 or 2ohm ... one diagram i seen on rockfords site shows the 2 subs wired together making 4ohms but then it will only have 1 pos and 1 neg wire so that would be for a mono amp not a 2 channel setup which i wanna do.. thanks for any help...
