Will JL Audio amplifier push this?
LHSroller
Will the JL 500/1 amplifier push a Triple 10 inch Visonik box? the RMS of the box is 600 or 800 (different sources, different numbers) it is probably better than the Legacy 1600 watt I am using right now huh? Thank you for your time.
yeh, itll push it ok, may even blow it - i never seen these subs but they look kinda budget - nothing wrong with that - but as a result the quality of materials, build etc - can it really withsatnd its rated RMS?????
i say, like audiolife, maybe some other subs???
Question--What's the final load for your enclosure? I'll assume 4 ohms.
My opinion is that what you hear will be similar to the legacy. Maybe slightly better. JL is known to rate thier amps fairly accurately so the 500/1 should give you 500-600 watts while I would guess the legacy at somewhere around 400-500, so I don't think there will be much of an audible difference.
I will say though, that the legacy could die tomorrow whereas the JL may last longer than you do.
LHSroller
LHSroller
Welch
n2audio
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
