Which brands produce a nice sound quality sub?
It's going to be my first sound quality set-up, and I hope it turns out pretty good.
Audiofrog GB12 is the best sounding sub i've ever heard. SSA and Sundown sound like muddy SPL subs in comparison
If you want sacrifice a little bit of SQ for some more output then Adire Audio Brahma and IDMax aren't bad options either
It's going to be my first sound quality set-up, and I hope it turns out pretty good. I'm going to start by getting subs and a amp. Do you all have any suggestions at which brands I should be looking at?
For actual proper SQ (which most people confuse with SPL brands that can sound ok with good tuning) your looking at brands like mosconi, audison, morel, zapco, hertz, audiofrog.....ect
A huge component of SQ is using a DSP for tuning and runnning the door speakers active (don't use the stock crossover boxes)
I know you said you where kind of limited to 10's, but these Stereo Integrity 12's are said to be designed for high quality output in small enclosures. Also, the QTS of these subs suggest they perform better in sealed applications and the manufacturer specs only call for 1 cube per sub.
It doesn't come in a 10 though, only draw back
Is the SSA Icon a decent upgrade from the American Bass XFL?
Edit: disregard this question. Now I'm looking into Audiofrog, Stereo integrity, adire, and ID max. Thanks for suggestions guys. I feel like I'm on the right track now.
Thank you for the info. Now I have a better idea of what to look at. Thanks!
I've always wondered how one defines a SQ sub. A sub's job is to play low notes. It's not like a speaker where you expect words to be clean and clear. Honest question really.
Note: Normally, I'd be worried about thread-jacking, but I can't hold a candle to the pickle talk.
Thanks man, I knew I was over looking some great options. Thanks!
Have an Xli 2500 as a sub amp in the music room, overkill for sure, never overheats, never skips a beat.
150
9K
Wow!! Very interesting to see some of what I thought Id see in the Top 10??
15
nice! yeah i don't know if that would be enough or not for the bigger setups... people here say it's enough for easily 10kw but i'll research...
14
Gatorade
Gatorade
Lexington, KY
LsGuy
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
