Where the Heck to put my JBL 1200.1
two.....
first; do you have room on the rear cab wall? like above your boxs?
second; this one is a little more time consuming and will probably eat $$$, anyway i just saw a excursion with bazooka amps mounted IN the doors. ( check this months issue of fourwheeler mag and look for the camo'd excursion) it was a pretty decent set-up!
here's one if you have a split bucket with center fold down console. either remove the center and build a rack for it or if it's like a hinged lid thing, mount the amp inside. that one could pose a heat problem though
if you dont have a passenger air bag you could put it where its supposed to be.
Any under seat room? You could build an encloised amp rack with cooling fans and just place it on the passenger side floor, or mount the rack to the box, or anywhere the box will fit. That's the nice thing about anclosed amp racks. If you build them properly, they pretty much cool them selves off as long as the ventilation is flowing through the box.
RangerMan
Premium Member
Premium Member
RangerMan
NC
natem33
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
