When using a roundover router bit on a slot ported 3/4 inch birch......
  • 6
germanyt
I plan on using a 3/4 inch roundover on all the edges but I run into a problem when I get to the port. The port is left of the driver and if I use a 3/4 on the inside and outside it's going to rout more of a point on the edge than a roundover.
On this pic it would be the right side wall. I suppose I could just roundover the outside edge and leave the port opening alone. Anyone have any suggestions for this. It'll be the first time I've ever used a router on a build.
I'd route the port opening 3/4 and the outside perimeter 1/2"
I was hoping you were online. Thanks for the quick reply. Does that leave the right side edge (in above pic) fairly rounded or does the roundover on the inside and outside cause it to come to a point? More like a V instead of a U.
Actually if you do both 1/2" you'll get that U roundover you're talking about. Scratch my first reply. When I do 3/4 port roundover I only do 1/4 perimeter to avoid the V shape.
LOL I ordered 16 router bits and not a one of them is a 1/2 inch roundover. Just my luck. I have a 3/4 and 3/8 coming.
Just saw you replied. Maybe I'll start with the 3/8 all over and see how I like it. I can always remove more material if need be.
Thanks a lot for the pic. Now that I'm looking at it I might pick up a 1/2 inch. I really wanted to round over the entire edge of the plywood with a 3/4 though for the aesthetics of all the layers rounded over. Maybe I'll 3/4 the outside and not mess with the port.
It's better to minimize the outer edge round over to keep the integrity of the enclosure imo. Rounding the port walls will ensure better airflow always.
I am using 45s and rounding the inside of the port walls. Just trying to maintain outside aesthetics. I'll start small and see how it looks. Saw comes Monday.
I used to do 3/8 on the port walls and 3/4" on the opening, but started just using the 3/8 all over. A larger radius will end up lopsided when doing the half moon at the end of the port. If you use screws, you'll get too close to them with a larger radius bit. I remove them to keep my bits safe, but sometimes the screw head will protrude due to the contour. Just doesn't look right.
Here's a 1/2" radius
3/8
Sent from my Motorola 2950 Special Edition 3w.
Loving the pics. Couldn't find any good ones on google. 1/2 inch looks pretty good. I am debating using screws and just pulling them or setting up my square and clamps and just using glue to eliminate the need to fill screw holes. I better jump on amazon and snag a 1/2 inch bit.
557
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
455
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
937
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
963
germanyt
germanyt
Ponchatoula, La
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
