whats wrong with my amp? weird.
xtcat8k
4
va
I recently purchased an alpine mrp-m350 from another user on this board. It was working fine for the first few days but as of last night, its been acting up and getting progressively worse. When I turn the car on, ill see the power light come on, but it only comes on for a second and flicker on and off..
I went to pull the fuses and happened to wiggle them a little and the amp started working again. But 5 minutes later, it stopped working again. I pulled the fuses on the amp and theyre still fine.
Any clue on what the hell is wrong? this *****.
ive checked all the other wires too.
trying using a new ground. if its not your battery or your ground it sounds to me like something wrong in the circuitry. if all else fails, bring it into a shop and have them test it for you.
Ill try a new ground. But its weird since everything was working fine. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif any other ideas on why its messed up?
You might have a cold solder joint or a wire short were the fuse holder mounts to the board. I would take the cover off, hook the amp up and turn it on. Touch the fuse again like you did and see if you can see anything happening in that area.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
In this Bidenconomy it is worth around $13,634. And a loaf of bread.
I think your front stage is spot on. If your DSP has a dongle that connects to your phone, then you are getting the full clear signal. No need to...
22
xtcat8k
xtcat8k
va
Dupuis
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
