what the hell is PHASE? AND WHATS THE DIFFEEANCE BETWEEN 0-180 DEGREES?
  • Thread starter Unregistered
  • Live activity
  • Replies 1
  • Views 1K
Don't hafta shout, dood..
"Phase" is the relationship between AC signals - in the case of audio, it's the relationship between sound waves.
"In Phase" means 2 signals (like left and right channels) are both moving in the same direction, either + or -, at the same time.
Phase is measured in degrees. 0 deg. is the same as "In Phase" - there's 0 degrees of difference. 180 degrees is when the 2 signals are exactly opposite each other.
The reference is usually to speaker polarities. You want all speakers to be "pushing out" or "pulling in" at the same time. If one is going out and the other is going in (180 degrees out of phase) they will cancel each other.
That's why it's important to put the + and - wires from your amps to the corresponding terminals on the speakers. You want all speakers to be in phase.
Guest
maylar
Doxquzme
    Aug 1, 2026
