What should my voltage be when my car is running...
  • 6
Well last night the voltage was 12.7 and this morning it is 13.7 I guess that's from the heat.
Either way I'm going to order a 250a ho alt from singer as soon as he answer my questions and sends an invoice
see:
A new alternator want give you more voltage if its PCM regulated
You need to make sure singer gives you an alternator that is not PCM regulated and gives you a bypass kit for your specific vehicle. You will come back and complain in a week about voltage if you do not do this
see:
My voltage at the main battery was 13.9 and 12.7 at the rear kinetik when it was 93 degrees outside after driving for a couple hours.
Guy at the battery shop said it's fine for now. My alternator has 90k miles on it so I'm ordering the new one.
I sent singer the model number off my alternator and he knows what car I have so hopefully he will know what I need exactly. Seems like he is trusted around here.
My alternator is in fact regulated
From singer:
"If you have the 2 wire plug (I do) called LIN bus ideally we need to stay on that plug. The bigger alt will stiffen voltage the way it should, that regulator design just does not allow us to achieve a higher voltage set point"
From singer:
What is the year and model of your vehicle?
From singer:
Another person you can ask is JS alternators. They're mostly on facebook so you can try messaging them there.
I personally wouldn't bother if you can't bypass the regulator. Total waste.
Your front battery voltage should equal your rear battery voltage. If it doesn't, your wiring is bad.
My grounds aren't the best. I'll check all my connections again thx
Ground your second battery to the frame and ground the amp to the battery
After the same drive I make every night with the amp ground to the frame I was at 13.8-13.9.
With the amp ground to the second battery it was 12.7 last night after the same trip.
I'm thinking maybe the original ground isn't very good so Im gonna try a different ground point with the amp ground to the battery.
The CT's are nice, That Sundown is a a frik'n beast!
513
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
468
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
554
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
881
danielbea122
CarAudio.com Exclusive
danielbea122
Tampa
danielbea122
Random4thGuy
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
