[AUDIO CONTROL] :
While listening to any source except in STANDBY state or Bluetooth mode.
Item Selectable setting (Preset: *)
SUB-W LEVEL –15 — 0 * — +15: Adjusts the subwoofer output level.
BASS BOOST B.BOOST LV1 */ B.BOOST LV2: Selects your preferred bass boost level. ; OFF: Cancels.
SYSTEM Q NATURAL */ USER/ ROCK/ POPS/ EASY/ TOP40/ JAZZ/ GAME: Selects a preset sound mode suitable to the
music genre. (Selects [uSER] to use the customized bass, middle, and treble settings.)
BASS ADJUST KDC-X695/ KDC-X395 only:
BASS CTR FRQ 40/ 50/ 60/ 70/ 80/ 100 */ 120/ 150: Selects the center frequency.
BASS LEVEL –8 — 0 * — +8: Adjusts the level.
BASS Q FACTOR 1.00 */ 1.25/ 1.50/ 2.00: Adjusts the quality factor.
BASS EXTEND ON: Turns on the extended bass. ; OFF *: Cancels.
MID ADJUST KDC-X695/ KDC-X395 only:
MID CTR FRQ 0.5K/ 1.0K/ 1.5K/ 2.0K *: Selects the center frequency.
MID LEVEL –8 — 0 * — +8: Adjusts the level.
MID Q FACTOR 1.00 */ 2.00: Adjusts the quality factor.
TRE ADJUST KDC-X695/ KDC-X395 only:
TRE CTR FRQ 10.0K/ 12.5K */ 15.0K/ 17.5K: Selects the center frequency.
TRE LEVEL –8 — 0 * — +8: Adjusts the level.
BASS LEVEL KDC-BT648U/ KDC-348U only:
–8 — 0 * — +8: Source tone memory: Adjusts the level to memorize in each source. (Before making an
adjustment, select the source you want to adjust.)
MID LEVEL
TRE LEVEL
BALANCE L15 — 0 * — R15: Adjusts the left and right speaker output balance.
FADER R15 — 0 * — F15: Adjusts the rear and front speaker output balance.
SUBWOOFER SET ON *: Turns on the subwoofer output. ; OFF: Cancels.
DETAILED SET
HPF FRONT THROUGH *: All signals are sent to the front speaker. ; 40/60/80/100/ 120/150/180/220 (HZ): Frequencies
lower than the specified value are cut off. (Underlined: KDC-X695/ KDC-X395 only)
HPF REAR THROUGH *: All signals are sent to the rear speaker. ; 40/60/80/100/ 120/150/180/220 (HZ): Frequencies
LPF
SUBWOOFER
THROUGH *: All signals are sent to the subwoofer. ; 50/60/80/100/120 (HZ): Frequencies higher than the
B64-4798-10_01_K.indb 28 11/01/06 15:07English 29
SUB-W PHASE REVERSE (180°)/ NORMAL (0°) *: Selects the phase angle of the subwoofer output to be in line with the
speaker output for optimum performance. (Selectable only if a setting other than [THROUGH] is selected for
[LPF SUBWOOFER].)
SUPREME SET ON *: Creates realistic sound by interpolating the high-frequency components that are lost in AAC/ MP3/
WMA audio compression. ; OFF: Cancels. (Selectable only when playback an AAC/ MP3/ WMA disc or a USB
device, except iPod.)
VOLUME OFFSET –8 — 0 * — +8 (for AUX) ; –8 — 0 * (for other sources): Presets the volume adjustment level of each
source. The volume level will automatically increase or decrease when you change the source. (Before making
an adjustment, select the source you want to adjust.)
what the interface looks like
