what kind of amp?
  • Thread starter <grimey>
  • Live activity
  • Replies 6
  • Views 979
<grimey>
Guest
i have a 10" audiobahn aluminum sub and i dont know what kind of amp i should get or what ones will work the my sub. Its like a 6 ohm something. How many watts x 1 should the amp be and at how many ohms ex: 400 x 400w @4 ohms
sounds like a dual 6 ohm voice coil and run in parallel comes out to 3 ohms.. so should work with any amp that will bridge to 400 watts unless it's 400 per voice coil then you will need and amp that puts out 800 watts.
Mike
here's an amp i've been looking at buying:
BRAND NEW FACTORY SEALED 400 Watt CHROME AUDIOBAHN AMP! Brand New Audiobahn 400 Watt Stereo Car Amplifier! Incredible Glossy Finish, Fan Cooling & BASS EQ! ** 400 Watts x 1 @ 4 ohms mono ** 100 watts rms x 2 @ 4 ohms stereo ** 200 watts max x 2 @ 4 ohms stereo ** Mono Bridgeable to 1 channel ** THD: 0.02% ** S/N Ratio: >100dB ** Variable 18dB Hi-pass Crossover: 120Hz - 750Hz ** Variable 18dB Low-pass Crossover: 30Hz - 120Hz ** Bass Boost @ 45Hz: 0/18dB ** Cooling Fan ** Cobalt Blue Neon Illumination ** High Gloss Chrome Plated Finish ** 1/2/3 Channel Operation ** RETAILS FOR OVER $399!
-would all 400 watts go into the sub or is that too weak of an amp?
Once again, this site will not let me post a new thread, so since this one is over three years old, I will go ahead and steal it.
Whats up guys. I am rebuildin the system, and the first thing I want to do is amplify my 6x9's. I have Pioneer TS-A6990R's, I bought them from:
http://www.sounddomain.com/item/PIOTSA6990R
I would like a nice 2 channel amp to power them, they can take about 80W RMS a piece. Thanks for the help.
Guest
radel2dope
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
