What is the cu.ft. of this
amedeuce
:crap:
The width is 15.5, These are outside dimensions.
Usually Im pretty good at this but I'm having a brain fart I guess. Im guessing it is around .58 cu.ft.
I hope the pic isnt hard to see. Here are the dimensions.
Height is 12.5"
Bottom depth is 11"
Top Depth is 4.5"
Front Height is 3"
3/4 inch mdf. Sorry. That is the site I use. The cal. they have doesnt include the extra dimension I have. The top side which is 4.5 inches. That's why I cant figure it out. In the block for height 2 on the calculator, Would I add the two numbers together and figure it that way? Like in height 2 put 7.5?
you could separate into a trapezoid & a rectangle....
a 3x11 rectangle, and then the height of the trapezoid would be 12.5-3 = 9.5
so you'd have for the trapezoid:
0.5 * h * (a + b)
0.5 * 9.5 * (4.5 + 11)
and for the rectangle, l * w.
3 * 11
add those up (0.5*9.5*(4.5+11)) + (3*11) and multiply by the width, 15.5
that would be the outer width; so for inner you'd have to account for the wood thickness
(((11*3)+(5.75*1.5)+(8.75*5.75*.5))*12.5)/1728
((33+8.625+25.15625)*12.5)/1728
(66.78125*12.5)/1728
834.765625/1728
approx. .48308195891203703 ft^3
amedeuce
:crap:
amedeuce
CA
urwhatueati8god
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
