What are THEE King of Bass Subs?
  • Thread starter <Matt>
  • Live activity
  • Replies 19
  • Views 3K
<Matt>
Guest
I am just curious as to what are thee best subs out there on any market, either personal or compitition. I am looking at running 4 12's in a Ext cab truck, what would be the best sub for that? Hi SPL, and High SQ, either DVC or SVC, the amp will be a Tarantula Amp from Soundstream. Thanx
Well there is no answer to your question as there really is no one "best" sub. Install, veicle, and experience with the product have great effects on how a speaker performs.
However, in a generalization; some of the more successful models for each Class today are found below.
SPL Applications
Digital Designs The Beast
Cerwin Vega Stroker
Kicker L7
Kicker Solo Barric
Adire Audio Tempest
Mmatts Jugernauts
Orion XTR
Atomic Thunder Shocker
SQ
Eclipse 88120ti
Eclipse 88120
Infinity Perfect
Soundstream Exact
Alumapro Alchemy
JlAudio W7
The best thing you can do is go to a few shows or even just listen to as many peoples systems as you can. Read the information available and make your decision from there.
A few good sites to get you started with information are:
www.meisearch.com
www.installdr.com
www.soundoff.org
www.iasca.com
www.sounddomain.com
www.soundillusions.net
I also have a complete listing of most major manufacturers in the mobile audio industry available and linked to on my site.
Soundwaves Car Stereo
My site is on a temp build platform right now but will be changing domains/servers soon. I try to keep an ammount of information available there that is useful. It is currently under construction, however, It does provide easy manufacturers website links to make thigs easier.
Do a little research, and let your ears decide what you like.
Take it easy.
-zane
Administrator
[ 12-06-2001: Message edited by: zane ]
The only one I know for sure that will also do high Sq is the Kicker L7..That thing sounds sweet.
The stroker is just plain SPL and the only info I have about DD is just hearsay, but looks like a straight SPL monster.
Zane if I am wrong correct me, I promise not to bite as long as you dont hurt my feelings while doing so.. Just kiddin
Mike
Originally posted by mykeys:The only one I know for sure that will also do high Sq is the Kicker L7..That thing sounds sweet.
Mike
The L7 has more of an even blend, however I would say that the Adire Audio Tempest carries the best blend overall. The Stroker- yup-SPL all the way, little SQ to be found. DD's are about 75/25 SPL/SQ blend from what I have seen.
Take it easy,
-zane
Thanx Zane. I have been very interested in competing for a long time now. I guess now is the time for it. I think I will give the Kicker L7's a shot. The blend between high SQ and SPL is what I am looking for. Its a LONG road ahead of me. Thanx for your help I am sure I will be needing it again in the future...thanx again
if you can afford a ****ing tarantula amp you should just try every kind of sub and find out which one you like. But seriously try Rockfor Fosgate or stroker if you want loud
If you want the ULTIMATE in SQ, try finding a person that will let go of their Phoenix Gold Cyclone. That baby is a work of art, it uses no voice coils, spiders, surround, or even a cone. It uses rotational magnets, it doesn't even look like a sub! Since it doesn't use any of thoose it achieves more than 3 times less distortion of a normal sub. Another thing that separates it from any other o called SQ sub is that it reaches sub-sub bass, hitting flawlessly down to 11 hz, with no problem at all. It's best sound level comes at 20 hz where most subs cut out. If you want one, look luck findng it, most people who use them use it for home audio now and won't let go of one for nothing. PG doesn't make them anymore, they were a sort of concept high tech sub in Oct 1999. Retail price is around $900 I believe.
I think I am go with the Kicker Solo-baric L715's. The Tarantula sould be able to pump those things damn good! Sealed boxs i was looking at 4.0 f3 for each one. I figured the middle should be best, not too much and not too little. I cant wait...its almost time to get this DONE!
Well those Adire subs are 8 ohm and are home speakers. But thats probly why you couldn't find them. Now Zane, have you heard these in a car/truck?? Have you used these on an install? or just seen them? They are designed to pump some serious bass thats for sure. Thanx!
man if i was you i would go with the Kove Armageddon Z series subs. kove is really really under rated. they have good sound...with kick *** bass. the Z come with a 2 year warranty. the Z 15 inch D series are 2x4.00 ohms and puts out 1050 watts.
Originally posted by MattNY:Well those Adire subs are 8 ohm and are home speakers. But thats probly why you couldn't find them. Now Zane, have you heard these in a car/truck?? Have you used these on an install? or just seen them? They are designed to pump some serious bass thats for sure. Thanx!
Yes, I have used the Adire Subs Quite a bit. A freind of mine actually metered at a peak 156db from a single Tempest(15") pushed by a Phoenix Gold XS2500 amps in an S-10. He now currently endorses Adire. Go to www.soundillusions.net and look up a person there with the screen name black00. He is the one responsible for this!
Very decent subs, and the cool part is, the president of Adire, Dan Wiggins, is very helpful and willing to discuss car audio with anyone. He frequently visits that forum as well as a few others.
Take it easy,
-zane
with those Adire's...would using the passive radiators add some more ummph? I checked out http://www.soundillusions.net pretty kewl site thanx. I will stop in there and ask black00 some questions, I am highly interested in the Adire subs. Any recommends on powered EQ's? Also do you use any specific brand Cap? I Love your website you got anwers for everything and anything! Thanx
Guest
80INCHES
Doxquzme
    Aug 17, 2026
firey_kimchi
    Aug 17, 2026
