What amp installation kit should I buy?
Great, but how can I know how much AMP do I need to put? I have 80 now, which is not enough because it blew up twice..
Yeah but that's the problem.. the manufacture just says that it can handle up to 250amp, that's all, no more information..
My bad ,I didnt mention that my sub is only 750 rms but my amplifier can do 1800 rms. although i'm planing to change that sub to something better.
is that ok to run a 4 gauge wire with something like 150amp fuse? or its too risky?
It really needs 0 gauge ofc. That’s exactly why it’s cutting off now with that cheap 4 gauge. So ofc 4 gauge may still not be enough. That amp is power hungry. If you’re broke and your dad’s cable is free (to you at least) then you “could” run two of those cables through one 200 amp fuse, but ideally you want to buy some ofc 0 gauge cable so you know you’re set.
1,800 watts ÷14.4 volts = 125 amps of of fusing. So, I would just switch to a 150 amp fuse for now and see what happens. If you have the money, then, just bite the bullet and get some 0 gauge.
ok I understand, so meanwhile I will use my dad's 4 gauge wire with 120amp (as I saw on most kits with 4 gauge ofc wire) just for the system to work, because now it is not working at all, I belive it is enough for a single 750 rms sub, and when I will upgrade my speakers and subwoofer I will buy a proper 0 gauge wire.
thank you all guys you really helped me appreciate you all :)
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
Best route is to start with a DSP. It will level and boost the signal with the option of having an amp remote trigger. For this you can tap before...
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
62
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
233
idan167
CarAudio.com Recruit
idan167
idan167
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
