what am i getting out of this amp? please help
anybodykilla200
im getting the audiobahn A2200HCX and its going to my 2 12 infinity perfects there svc, what kind of loads do i have to work with? my friend who has the same amp as i said that he got 600 watts to each of his 4 ohm svc speakers will i have this as well? here are the amp specs please help me out :
200 watts x 2 @ 4 ohms stereo | 400 watts x 2 @ 2 ohms stereo | 600 watts x 2 @ 1 ohm stereo | 1600 watts x 1 @ 1 ohms mono | Dimensions: 3.5"(H) x 12"(W) x 24"(D) , High Current Circuitry | PWM MOSFET Power Supply | Double Sided Glass Epoxy Circuit Board | S/N Ratio: >100dB | Frequency Response: 10Hz – 40KHz (+/- 1dB) | Remote Bass Control With Blue Backlight Knobs | Variable 24dB High-pass Crossover: 90Hz – 750Hz | Variable 24dB Lo-pass Crossover: 30Hz – 120Hz | Variable Subsonic Filter: 20Hz to 45Hz | Variable Bass Boost: 0 – 18dB | Variable Bass Boost Frequency: 40Hz – 100Hz | RCA Throughput Connections 4-way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset | Dual Cooling Fans | VU Meters Indicating Output Response | Cobalt Blue Illumination | High Gloss 14K Gold and Chrome Plated Finish | Nickel Plated Block Terminals
Yes, you'll have the same configuration.
You want your amp bridged and subs wired paralell. You'll have a 2 ohm mono load on your amp which is the same as 1 ohm stereo. You'll get about 600 rms to each sub.
anybodykilla200
anybodykilla200
Compton
n2audio
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
