I realize that and I didn't mean to sound like a dick after i read it I changed it, it's been a long day doing jaydubbs alt and wiring along with a second battery install 8.5 straight hours basically under the hood or in the trunk!Well next time, get straight to the point because you're not very good with "hints".
yea I figured it was something BIG sounds like it's going to be badass man make sure to make a log and take plenty of pics.4 skar vvx 15s. i got for a steal. autotek mean machine 4000 the old model that does rated a lot of deadener a lot of wire. 4 aq super tweets. 6 pwx 8. ppi black ice 800.4... hmmm 80 prs... dc alt 370 amp... 2 xs d31... i feel like im leaving something out.
well I would add a few big agm deepcycles to the list of stuff it's the backbone of any large system!how does the set up sound to you guys? any suggestions? i mean ive running on these forums just looking at all the info i can and gathering everything up slowly as i see deals but a lot of it still has to be new.
I would ditch the red top your going to kill it with that system, and yea the biggest thing you can fit under the hood along with two more large ones in the back if not three you have the alt to charge them and catman has some nice battery's I put in a HO alt today with one at first and at full tilt at idle we were seeing low 12's after adding a second battery it helped stiffen it to the high 12's low 13's but that was on 1500rms your talking about 4000rms, so in short yea more battery's for sure!i have a red top under the good and i just order some xs d31. you think i need more?
thanks for the info i will order 3 more xs d31 and put one under the hood.I would ditch the red top your going to kill it with that system, and yea the biggest thing you can fit under the hood along with two more large ones in the back if not three you have the alt to charge them and catman has some nice battery's I put in a HO alt today with one at first and at full tilt at idle we were seeing low 12's after adding a second battery it helped stiffen it to the high 12's low 13's but that was on 1500rms your talking about 4000rms, so in short yea more battery's for sure!
well that sounds best your going big no reason to cut any corners especially on your electrical.thanks for the info i will order 3 more xs d31 and put one under the hood.
also double up on 0g from the front battery to the back ones and just the single from the front battery to the alt and you may want to get a fuse block that has just bolt studs so you can double stack two 250amp fuses for 500 total with that alt being **** near 400amps of constant output.thats good to know. glad i have finished the build then saw the voltage drop. i will pick up some more to be safe
yep pm me about it cause I'm about to pass the hell out I'm off to bed I'll give you a rundown of what would be good and solid tomorrow when I get up.will do. any more suggestions?
