noob with an RS
i poop on you
whats the difference with drinking weight gainer shakes (such as cytogainer and meal replacement shakes) and drinking protein shakes?
And which time of day do you take each one? (after meal, anytime, after workout?)whats the difference with drinking weight gainer shakes (such as cytogainer and meal replacement shakes) and drinking protein shakes?
If you want to gain weight stop all cardio for now. Increase your caloric intake above what it currently is lift heavy with low reps for your sets. Take whey protein stay away from soy as it isn't very good for you in high doses. Try allthewhey.com. Also if you can't get enough calories during the day try adding a mass gain shake into your diet. I did this and gained 20 pounds with little increase in body fat. To minimize body fat gain don't try and gain all the weight at once; be patient. Also realize that in order to gain bulk your body fat will have to temporarily increase because you have to have a surplus of food. If you don't your muscle won't be able to grow. Also cut out the alcohol drinking, this will only cause your body to store more fat and will dump your natural testosterone levels (temporarily ofcourse). No drugs use either.Since I dont want to jack the other thread, lets finish the convo in here.
I need tips on how to start taking protein, IE what kinda, how much, when, etc.
I weigh around 145-150lbs right now, I workout 3 times a week for about an hour, and I do lots of high row, DB bench, and front lift stuff, with ending in abs. Im going to start doing legs on my off days I think,and adding more cardio.
I'd like to gain at least 10-15lbs.
Help?
weight gainers do just that: make you gain weight. protein is just thatrotein
weight gainers are pretty much useless, just eat lots of healthy lean foods
i know about the phases //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifDisagree. If used responsibly and if you select a high quality weight gainer you will see results. In order to get bigger you have to gain weight. Any bodybuilder will tell you prior to a contest they go to a cutting phase. Prior to the cutting phase they were bulking.
You don't want to take just protein after a work out. You have to get carbs/ calories in you. The two most important times to eat are prior to a workout and immediately after.Full well rounded meals are far better than protien shakes and weight gainer. weight gainer is loded with calories and other things that whey protiend dosnt have. Ideally you just want to take a protien shake post workout. stick to eating 5-6 smaller meals a day. eat lots of protiens. track how many calories you eat and watch your weight then adjust your caliores to get the desired effect weather it be gain or lose weight
can I mix my protein shake w/ some OJ?
ahh, wasn't sure because some people think that
a. fat turns into muscle the more you workout
b. more muscle = faster fat loss
two great myths. first one is NOT true in the least and the 2nd one has not been proven to be true //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
