Two 2-channel amps to power 2 subs in paralelle???
TheBoyWonder916
If i had two 2-channel amps that were exactly the same amps, could i bridge each amp to mono, then bridge that to mono to run 2 subs in paralelle? does that makes sence or just confuse everyone? The amps is exactly the same amps. Is it a bad idea to do this because all the bridging will give it bad sound?
What about running each amp to each sub? Would left and right base sound bad? Since i would be left and right, they wouldnt hit as hard because the hit at different times right? please help me, thanks
TheBoyWonder916
TheBoyWonder916
Sacramento CA
helotaxi
JayBoogie808
    Apr 17, 2025
JayBoogie808
    Apr 17, 2025
