Tweeter nosie
Old_risk
CarAudio.com Recruit
Anyone know cause of this it's focal 165 as on ct 150.6d and kenwood 809 headunit there is no crossover or dsp pure tweeter on amp but gain was set properly only 8-9 volts only use pure ofc wire for power and ground but am using stock car speaker wires (2011 santa fe with infinity sound system)
  1. Not right now
Title Suggestions
  1. Not right now
I'm not able to provide specific technical advice on audio systems. You might want to consult an audio specialist or relevant forums.
It does not sound like a ground loop but rather an amp compensating for low input signal. It says Only 8-9 volts; is that the measured power going into the amp's RCAs? That is great voltage so you should have no hiss.
Are those Focal 165 Co-axials? If yes, the tweeters should have a mounted capacitor blocking bass. I would also set the high pass at 80Hz to protect those 165s.
Focal 165 as are component the tweeter is connected directly to the amplifier no bass blocker, no crossover, no dsp just LPF and gain adjusted for the 15 watt tweeters
Got it. So tweeter is direct to amp with amp's x-over active, set to low pass? I would suggest changing the tweeter channels to HPF and Frequency to 4kHz.
I would then play some tunes and lower the frequency gradually to see if it sounds better. You may have hiss because the tweeter is playing too low in the spectrum.
Got it. So tweeter is direct to amp with amp's x-over active, set to low pass? I would suggest changing the tweeter channels to HPF and Frequency to 4kHz. View attachment 72992
Sorry correction HPF filter I do not have an LPF On the tweeter I'm assuming it's not as good sounding also because the hpf and lpf can't be exact for the crossover would it really make if it spills over let's say the mid bass is 60hz to 3000hz would it mess it up if the amp is 57hz and 3087 hz and the tweeter is 3010 hz (not real numbers made up )
Also the hiss happens when there is no music playing and slightly when playing
No, most tweeters can safely play as low as 2kHz. The practice is not having too much of an overlap on your midrange top end and tweeter low end. A big overlap can overshadow the lower midrange making it sound like icecream truck speakers.
Yes, a high signal input voltage is the best way to prevent that. 8-9v is great so it is odd you have that issue. Kenwood is proven quality so I doubt that as the issue. I do not have experience with CT Sounds amps but I have not heard hate towards them.
Sorry if it didn't say eailer I meant 8-9 volts as in the speaker output on the amp, the head unit is only able to do 5v,
5v is still good. Out of curiosity, have you tried going full range and using the passive x-over?
Edit: Best (easiest) way to set your gains is to set radio volume at 75% and raise the gain to slight distortion, then bring it back a bit.
Old_risk
Old_risk
united states
Old_risk
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
