trying to make a enclosure and i have a question
  • 5
ekah
hawaii
i wanted to make a binding post instead of drilling 2 wires into my box since i dont like using cups
i wanted to do the binding post or like the bolts and washer etc
what sort of washer and bolt and nut should i use?
like material?
when i go to home depot what do i look for?
or could it just be any sort of bolt and washer etc like zinc?
or is there a certain bolt i should get for best conductive?
They're cheap too around 5 $ depending on which ones you go with. I use them on all my enclosures.
Shipping might be an issue for you though being in Hawaii so you may want to order more than binding post. Like maybe some ofc 4 gauge wire you need for your buddies build. Yeah don't do 8 gauge to a distribution block split into 2 8 guage. I would even consider 0 or 2 awg welding wire to distribution block even better current flow and more room to grow but 4 guage will get the job done
I bought these at Home Depot. It looks the same inside the box.
i just used this for mine, works great. plugged the wires straight in
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
385
Just need to find id to get a users Manuel thanks
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
ekah
ekah
hawaii
nauc
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
