Tons of install accesories all Rockford Fosgate - Perfect Interface
Goindef154
Nothing
5,477
Phoenix, AZ
--4 pack of female connectors 12 or 16 gauge in black - $.25 each pack
--4 pack of 12 or 16 gauge fork terminals in black - $.40 each pack
--90 degree 4 pack of 12 or 16 gauge fork terminals in black - $.40 each pack
--4 pack of 8 gauge fork terminals 2 red/2 black in each - $.75 each pack
--4 pack of 4 gauge Couplers in red or black- $.50 each pack
--4 pack of 8 gauge couplers in black - .50 each pack
--4 pack of Monster 30 amp AGU fuses - $2.00 each pack
--Three 4 gauge in to four 8 gauge out AGU Fuse block - $8.00 each
--90 degree RCA plug adapters - $1.25 each
Some of the packages are dirty but everything is brand new
They all have rubber inserts that go over them, not the cheap plastic ones.
Prices are above^^^^
Everything is plus shipping but since they're light shipping is usually cheaper, like around $2-3 usually.
No such thing as a dumb question //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif. They're barrel crimp connectors, if you have two 4 gauge wire you want to connect then these get the job done for you //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
718
Thank you for your kind replies. I have decided to use an amplifier I purchased for another install, but subsequently never used. I was...
912
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Goindef154
Nothing
Goindef154
Phoenix, AZ
Gordon 24
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
