Bumpbump
Subwoofer wiring information
Here's one for the bassheads who think they know every wiring trick
One thing I see people overlook all the time is that you can't always find an electrical problem by just looking at the wiring or checking the final ohm load. If I really wanted to hunt down a problem in a high-power system, I'd put the system under load and start doing voltage-drop measurements across the actual power path. Battery + to amp +. Amp ground to battery –. Then start checking across the fuse holder, distribution blocks, terminals, crimps and other connections. Because here's the crazy part: a connection can look PERFECT sitting there with the system off, but once you make that connection carry serious current, resistance at that one connection can turn into a measurable voltage drop. Same thing with multiple subs wired in parallel. Just because they're wired the same doesn't automatically mean every branch is sharing current exactly the same. Coil resistance, wire resistance, connections and even differences between the subs can affect the current distribution. And don't get fooled by a DMM telling you “1 ohm.”
That's DC resistance. Your amp is dealing with an AC impedance that changes with frequency. So if you REALLY wanna troubleshoot a bass system, stop looking at just the number printed on the sub and start measuring what the electrical system is actually doing while it's under load. That's where you find the shit people miss.
- Photo
- Not right now
