THE Thread
you had to google it too? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/noevil.gif.0723d47b61c306c6d554fb6555014096.gif
I mean what did you do once you got there.
Why kurt thomas?
I kinda liked the idea of floaters, but then I saw them and said nah thats pretty whack.
i turned around and drove back
Kurt Thomas because at the time we thought about it everyone was calling "spinners" "sprewells" and kurt thomas was the worst slowest player on the knicks with sprewell so it seemed to fit
ok first, you wire the positive wire from the left channel to the pisitive terminal on sub 1. Then, run that wire to the positive on sub 2. then you connect that to the positive on the right channel. Then, do the same with the negatives. Then, you run a wire from the positive on sub 1 to the negative on sub 2, and then a wire from the negative on sub 1 to the positive on sub 2. then run a wire from the posiive on the right channel to the positive on sub 1, nd a negative from the left chnnel to sub 2, and vice versa.
If you do this correctly, it should look like this:
... and your amp will probably fry. Good luck getting 2 4 ohm SVC subs to make 2 ohms stereo. Any more stupid questions?
//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
RangerMan
Premium Member
Premium Member
RangerMan
NC
x2o
