telling maintenance to fock off
that was the best part of that entire movie //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif the rest sucked
and the thing is, it was free to watch in the commercial.
Well I downloaded it anyways so the whole thing was free for me too.
i do HVAC for a living .....sounds like you need a new thermostat ...just make sure the wire you are taking off is not line voltage (120v) some electric heat base boards used line voltage to t-stat and some used low voltage 24v
the strips run on what looks like a pair of relays....the wire I removed was one of the lines from thermo to relay* that is supposed to turn off with the thermo. all this based on the wire diagram on the unit.
uploading pics now
brown was always off, I removed the white
do you have a/c in your apt??????? w2- white wire =heat r-red wire=power g-green wire=fan y-yellow wire=a/c o-orange wire =????? x-blue wire=???? usually if that was low voltage it would be 18 gauge wire ...but that looks like 14 gauge wire maybe line voltage if so be VERY CAREFUL ....check the red wire with a meter to make sure ....... the orange and blue wire not sure what they control with out looking at the wiring diagram
ok maybe it just the way the picture came out ...looks like 14 gauge ....if its small gauge wire its 24v and not 120v .....but that looks like a special t stat not the kind you can get at home depot ...that o-e-x terminals are not common on over the counter store bought t stats
the camera was less than 3" away from the "block"! 24v at the red btw...and i am fine turning the strips on via emergency heat if it gets below 40degrees:D
dman4486
RememberedHowToChangethis
dman4486
Fountain Inn, SC
Injected54
