system
i think 85x4 will be good enough, it all really boils down to where u put it at..
consider mounting your tweeter up high... but first of all pick your speakers over your amp then match it up.
Disconnect the amp for a day or two, then connect it back up. If it stops draining when unplugged then drains again, take it back and have them...
I would also recommend checking all the amps wiring to make sure secured/ tight and ground is solid and remote making solid contact in the terminal
7
615
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
563
derekdemanes
derekdemanes
Chicago,il
limitkid7
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
