system suggestions
bryguy1701
hiya all - i could use a little input on my choice of subs / amp here. Reason I'm asking is that I'd like to know which products have good quality, etc so I dont have to buy new subs/amp again.
I am trying to decide between:
1. 2 12 inch JL W3-D4 subs
-or-
2. 2 12 inch Rockford Fosgate HX2 Punch subs
I'll be buying off of ebay or other cheapest alternative. Any suggestions on what amp I will need to drive either of these subs? And which subs would you suggest for cost/quality ratio. I'm not looking to spend a #$*&load of money. Just enough to get the job done. (I'm more a fan of SQ). I'm willing to build either a ported or sealed box. I just had 4 ohm speaker wire installed in my 02 Civic Ex Coupe so I'm ready to buy #$*$ and put it together. //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
Your actually compairing JL subs to RF subs?? Go with the JL's hands down. (If your interested, I can hook you up with a pair of Power Bass ES-12's for 250 + shipping.) As for an amp, there are a lot out there that will get the job done with out spending a ton of $$.
What do you mean by already have the 4ohm speaker wire??
Right - i guess my question is - what is enough to get the job done - i want a slightly above mid-range system, so I guess that means a slightly above mid-range amp.
And about your decision towards JL Audio - do you have any reasons regarding the two models?
I already have the 4-guage wire installed from my battery to the back (including sound from H/U and ground). Point being all I have to do is buy my system now and install it.
How do those subs compare to the W3-D4's?
bryguy1701
bryguy1701
tulsa, az
Trixter
BP1Fanatic
    Apr 25, 2025
BP1Fanatic
    Apr 25, 2025
