System Recommendation 2002 Camaro
  • Thread starter <M2002SSF>
  • Live activity
  • Replies 4
  • Views 1K
<M2002SSF>
Guest
I got my 2002 Camaro SS with the Monsoon system (standard unforunetly) and all though it doesnt sound bad I would like to change it out. Just wanted to see what recommendations might have for a install. The doors are 6.5" as are the back panels and I am going to get a stealth box for the back for something like an Infinity Perfect 10.1 or Eclipse (
You can use any head unit, the monsoon sys. amps don't use a remote turn on, they use signal sensing, so if you change out the head, the factory amp will turn when you turn the head on and the cool thing is that they automatically adj. themselves for the amount of input voltage,
The only problem with this car is that it may have the gm class II databus system through the factory head, so if you change it out you will have to relocate the factory head and wire it up, Best Kits makes a bypass harness for this, BHA2004t (I think that's the number) and would cost about $70-$80.
^what he said.
//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif 3,000th post! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
^what he said.
whor3 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Guest
Beat_Dominator
randy hagan
    Jul 15, 2026
