Sweet Megacab Box
More info please?
I just don't see 2-15's working well in the space you have to build.
T/S specs.....designed for small boxes.
fs 35.66 hz
qms 4.74
vas 1.54 ft^3
mms 468.3g
revc 2 ohms in series
qes .36
spl 89.2 db 1w1m
qts .34
le 2.81 mh
bl 25.33
How exactly does the port work with it tapering like that? Does it act similar to a horn?
Not really. The taper is to control the peak from a much larger compression area than what a horn utilizes in most cases for coupling. Its a good balance with moderate efficiency. here is the anechoic response:
Now keep in mind this was design with only dimensions given by the client. No specific preferences were given and this was designed mainly on usability. I did what I could with the limitations, and the design shape as a priority as well.
More info please?
Yea, it was a challenge. You have a point. The limitations were great in this design. We did what we could with what we had. The baffle will also be using a seperate baffle for mounting depth as well. I have an idea for the client that he may like for that one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
CHEMMINS
CHEMMINS
Nevernever Land
CHEMMINS
