Subwoofer cable
rr14
22
WA
I am looking for a good cable for the sub and i just wondering what do you guys usually use and what is the size of the cable.
I tried to find on the net but the biggest speaker cable size that i found is 12ga which i think not big enough for the sub.
Thanks
Unless you're crossing your sub high, I don't think you'd hear a difference in a blind test between ab and d
187
My guess is, once you get the speaker in it, more like 34hz so good to go. With that unit, try it up, try it to the rear, see which works best...
12
248
Two of these in that box would work great. https://www.ctsounds.com/collections/tropoxl-subwoofers/products/tropo-xl-12
12
469
Wrong setting used on the meter. There are tutorials on how to use them properly for the need. You can also be able to download the specs for the...
12
786
The free software I use is Torres to rough in the overall size, Winisd or BBpro to model volumes, velocities, response etc. I can also to some...
10
rr14
rr14
WA
paikiah
Jimi77
    Jul 13, 2024
Jimi77
    Jul 13, 2024
