94gmsierra
s ub A sub B
max power (coils in series)~ 400w~ 600w
cont. power " "~ 200w ~ 300w
SPL (coils in series)~ 85.3dB ~ 82dB
freq. Response ~ 20 Hz-1.5kHz ~ 20Hz-2.0kHz
cone mtrl~ polypropylene w/titanium ~ glass fiber
woofer magnet~ strontium ferrite 33oz ~ strontium Ferrite 62 oz.
woofer basket ~ stamped steel~ Aluminum
cone surround mtrl~ NBR Rubber ~Rubber
outside dia.~ 10 1/8" ~10"
mounting hole~ 230.2mm ~231mm
mounting depth~ 127mm ~35mm
sensitivity ~ 82.3/85.3 ~ 82dB
max peak music~ 400w~ 600w
cont power~ 200w ~ 300w
nominal impedence~ 4/8 ohms ~ 4 + 4 ohm
Re DC Imp. (+-10%)~ 3.3/6.4 ohms~ 7 ohm in series
Le~ 1.05/4.44mH~ 2.34/5.79mH
V.C. Dia.~ 50.8mm ~ 50.8
Sd~ .0366msquared~ .0333msquared
Vas~ 26.13 L~ 24.9578L (paralleled)
Fs~ 41.6 Hz~ 32.2463 Hz
Qts~ 1.38/.76~ .5316 (paralleled)
Qes~ 1.58/.78~ .6261 (paralleled)
Mms~ 05.4g~ 151.3986g (paralleled)
Mmd~ 101.4g~ 147.9547g (paralleled)
Rms~ 3.44kg/s~ 8.7056?m (paralleled)
Bl~ 7.2/14.6 Tm~ 18.51Tm (paralleled)
Speaker displacement ~ 140"cubed®/105"cubed(F)~ .0333msquared
Xmax~ 9.2mm~ 7.5mm
Magnet weight~ 33 oz.~ 62oz.
Can anyone tell me if one will be obviously better and louder, from what i learned sub B will be a quieter subA?? But it is supposed to be far superior to SubA, and i don't know if im getting Bs'ed into a sale. These are clarions by the way, if anyone knows of subs that even far better then this please let me know. Thank You Sorry for this post being a mess.
Xmax~ 9.2mm~ 7.5mm
