Street glow undercar neon problem help!
Silica
My buddy installed his undercar neon kit, fired it up works perfect, anyways he got a sway bar and installed it on his car, he put the **** thing on backwards and the bar crossed the output wire ont he alternator and starting arc welding like a *****. Fried his alternator, anyways, he got a new alternator blah blah cars back to wrunning, anyways, the undercar neons now when you turn it on it just turns on for 1/4 of a second and turns off, just flickers.. figured the transformer was toast. Warrentied it, installed a new one and it does the exact same thing.. flickers once everytime you turn it on and off...
any ideas???
thanx
Tim //content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif
Most likely that one of the tubes is either cracked, inner or outer tube, or there is a loose connection somehwere in one of the tubes. I suggest you test each tube individually if you have the time/motivation.
Silica
Silica
Cambridge Ontario Canada Earth
Gen 6 Celica
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
