jimmyslide
Let me get you a spoon...
Stay with me here for a minute. I hate when others ask these questions, but I have to. I am in a tough position and need subs badly. I want to run either 2 12s or 2 10s. The 12 will likely be sealed due to the box size and the 10s will probably be ported. I am leaning towards the infinity because I have always been a fan of them. Price is not an issue as my friends has some really good connections and they are both rediculously cheap. And no, they are not stolen.
I think the Pioneers will be a little louder, but the infinity will sound much cleaner. I have heard the pioneers in a setup in a truck and it was pretty good for the price. I have not heard the infinitys in a real setup.
HELP!!!!!! //content.invisioncic.com/y282845/emoticons/scared.gif.f134e57c6c93ccd0f15aa5ac32c7d4a0.gif I am freakin' out...
Pioneer TS-W305C
Aramid Fiber IMPP (Injection Molded Polypropylene) Composite Cone
Wide Urethane Surround
Conex Spider with Damper Ring
Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
Projected Yoke with Vented Pole Piece
High-Energy Ferrite Magnet with Bumped Back Plate
Low-Q Design for use in Small Sealed Box
Rec. Sealed Box Dims: 1.10 - 1.30 cu.ft.
Rec. Ported Box Dims: 1.20 - 1.40 cu.ft.
Free Air Usage: not recommended
Sensitivity: 89 dB
Frequency Response: 18-2,500 Hz
Recommended RMS Power: 400W
Peak Power Handling: 800W
-----------------------OR-----------------------
Infinity Reference 1230W
Polypropylene Cone
Large-Roll Butyl Rubber Surround
Dual Stacked Magnets
Bumped Backplate
Vented Polepiece
Progressive Spider
Deep-Draw I-Beam Steel Basket
Mounting Depth: 6 1/4"
Rec. Sealed Box Dims: 1.25 cu.ft.
Rec. Ported Box Dims: 2.00 cu.ft.
Free Air Usage: yes
Sensitivity: 92 dB
Frequency Response: 25-250 Hz
Recommended RMS Power: 300W
Peak Power Handling: 1200W
Pioneer TS-W305C
Sensitivity: 89 dB
Polypropylene Cone
Bumped Backplate
Vented Polepiece
Progressive Spider
Free Air Usage: yes
Sensitivity: 92 dB
