sony 10" vs. re8
pj2003
currently i have 2 sony xplod p5 10"subs in a sealed box with 175 watts goin to each one. what i want to do is get 4 re8's and port them with each sub in a 0.5 cu.ft. box for each. which would hit lower?which would be louder? which would have better sound quality? and which would rock the block the best.by the way it is goin in a reg cab silverado........also if anyone knows what would 4 re8's ported hit in db's?????? oh yea each re8 would get 87 watts........same amp as for the sony's
re would be better in every way, and i dont know what it would hit u would just have to find out,and as the amp you will prob need to get a bigger amp
do yall think 87 watts apiece is enuff.....i have heard that re8's when they are ported have bottomed out with 130 watts so i "think" 87 would work well
It's all in the install. I have 200 watts on each with no problems. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Why not just get 2 so you have plenty of power, I'm sure you would be happy with 2 for now. Everyone says they are awesome. Then if you want 2 more eventually you can get a new amp too.
i think i might jus go ahead and get the 4 of em and send em 87 watts apiece and see how i like it..........but if i nee d more i'll look into a 600 watt amp......any suggestions......amp cannot be a huge amp cuz i'm gonna hafta put it under my seat so i would prefer a class d
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
pj2003
pj2003
thomasville
denim
Bobbytwonames
    Jul 20, 2024
