Im picking up a 24-36" sonotube tomorrow for a HT subwoofer project and would like some tips on construction.
First off, Im using an Avalanche 18 and would like a port tuning between 14-16hz. Whats optimal for ports to avoid chuffing (surface area or depth)? It will be downfiring along with the sub so I have lots of options. I will be using PVC pipe for the ports.
How do I attach the caps to the tube itself? How thick should I go (2 x 3/4 mdf for each cap and 2 x 3/4 for the inside of the tube?)
Secondly, it being a HUGE enclosure (8 feet tall and at least 24" wide) how much power would I need to reach maximum excursion?
Would a Bash 500 watt amp work or should I go with the Behringer EP2500?
