something aint right... help
rustycar
alight here is the prolblem,
ford escort, alpine 9821(cd), alpine swe10(sub), rf501bd(amp).
the amp is 500w rms@2ohm, 300w rms@4ohm, 10''subs are 200w rms 600w max @4ohm.
i have two subs that when i hook both up to the amp @2ohm i dont have much power. when i hook one sub to the amp @4ohm it bumps alot harder. how can i get both of these subs bangin?
you said you wire + from amp to + on one speaker and then wire to the other + on the other sub. Try wiring + on your amp to + of the first speaker to - on the other speaker. The terminal may be labeled wrong. Cause what you are describing is very typical with cancellation due to polarity.
rustycar
rustycar
harrisville
stangme01
Emanuel Rodriguez
    Apr 19, 2025
Emanuel Rodriguez
    Apr 19, 2025
