Screwy CD player
Bodawg111
we just got done installing an older Sony mp3 deck and amp wiring into my friends '99 Honda Accord. When i hooked it up, the player worked fine and sounded really good. He also has two JL 10s and no amp so we hooked a Legacy 1000 watt i had laying around, and everything worked beautifully. But, after we took the amp out, he noticed that everytime he hits a button or turns the vol all the way down, it makes a low thumping/popping noise in all for speakers. On top of that he claims his radio started making a static interference type noise that would change respectively with the gas pedal. Ive had some weird stuff happen before but not like this. Let me know if you need more info. Thanks!
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
836
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
Bodawg111
Bodawg111
Longview, Tx
tomd
Bobbytwonames
    Jul 19, 2024
Bobbytwonames
    Jul 19, 2024
