Which would you prefer? I'm under the impression they're basically the same thing and that if one can tool can handle one application, so can the other one.
I just need to know which would be better for:
1. cutting straight lines (mdf)
2. cutting circles (mdf)
3. cutting fiberglass
I had a dremel-compatible mini-rotary tool that I was cutting fiberglass with (bit #542) and all of it sudden it just stopped and won't turn on. took the case off and checked all wires were still hooked/soldered up, but still no go. So I need a new rotary tool asap so I can finish cutting.
which is better; no, wait, which is better for the applications I've mentioned above?
