Rockford fosgate t1000-1bdcp for sale mint with bass knob
cleansoundzz
Buena Park
General Features:
Constant Power Series Monoblock Class bD Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 700 watts x 1 chan.
2 ohms: 1,000 watts x 1 chan.
1 ohm: 1,000 watts x 1 chan.
Dynamic Power Output: 1320 watts
Remote bass level input (Punch PEQ remote level control sold separately)
LED power (blue), protect (yellow) and thermal (red) indicators
Variable Bass Boost (0 to +18 dB bass boost at 45 Hz)
Gyrator based punch EQ eliminates frequency shift with boost
Mono channel operation
Audiophile grade speaker connections
Preamp Pass-Thru RCA outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Dual speaker terminals simplify the hookup of multiple speakers
Heavy duty cast aluminum convection heatsink with Direct Thermal Management evenly distributes heat across the entire heatsink for improved efficiency
Nickel-plated RCA level inputs
Nickel-plated clamp wire terminals
Input sensitivity:
Level: 150mV-5V
Variable low-pass filter (35-250 Hz, 24 dB/octave Butterworth)
Selectable Infrasonic filter (12 dB/Octave, -3dB at 28 Hz)
Damping factor: >200
CEA-2006 compliant amplifier
Frequency response: 20-250 Hz
Designed and Engineered in the U.S.A.
External 150A fuse required and sold separately
Dimensions: 13-11/16"L x 8-3/16"W x 2-3/16"H
4-gauge power and ground wiring is required for installation
MINT, COMES WITH INSTRUCTIONS, BIRTHSHEET AND BASS KNOB
$315 SHIPPED-NO TRADES
SHIPPED IN THE UNITED STATES ONLY
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
