Replaced a stitched subwoofer surround
MattinMO
 So I have a sundown sa12 that the surround is damaged beyond patching and it stitched I contact at sundown to see if they have some type of replacement surround available I’ve also looked around and seeing what might work for the sub as in when he ever replace just the surround on a stitched to surround sub? Obviously I won’t be able to stitch the new surround in which is fine as long as it stays together
Sounds like you need to recone it.
http://www.caraudioclassifieds.org/forum/sundown-audio/243714-sundown-drop-kit-prices-updated-11-3-16-a.html
This thread is worthless without pics. Just because you have a stitched surround doesn't mean it can't be fix but I'm not gonna sit here and guess what the damage looks like.
 What difference does it make what the damage looks like it’s got to be replaced. from rubbing up against the seat and a truck and there’s  pieces of rubber missing from crumbling from rubbing against the seat. Got sub from a friend for the free. It was still thumping and he had no idea what he had done to the sub until he flipped his seat forward to swap amps
Because it's impossible for someone over the internet to just guess if it can be fixed. It's hard enough just seeing pics. Without, come on bro. Didn't know if it was a small tear or what. Butt fukk. That's pretty rough. I'd fix it. It's just foam glued to two more solid surfaces. I don't know how smart you are, but I could fix that.
I’ve had to replace quite a few jl shitty foam surrounds so shouldn’t be much different other then having to take out the stitches
Sundown had a yard sale where they were selling surrounds, spiders, coils, caps and everything for people to build their own drop ins. Im sure Dave leib can hook you up with just a surround.  I personally would just get a drop in with an american coil.
Agree. But I also know where Op is coming from. I would use duct tape.Thor's Hammers.
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
MattinMO
MattinMO
St.louis, MO
audiobaun
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
