Remote wire problem
BigPanch
Any one know why does the Amp remote( blue sripe wire) work with the red cables and not with the blue with a white stripe wire behinde the deck. So the blue white striped wire behinde the deck is still loose with tape on the tip of the wire . Is their a problem or is that how it work.
i guess it is not a problem because it turns off when its suppose to and turns on when turn the key so thanks i just finished installin the sound system and i dont have any problems with it now.
The difference between the "blue" and the "red" is when the current runs through the wire. As you have found, your amp turns on when your key is on. If you use the "blue" or remote amp turn-on lead, your amp will turn on when your radio is powered. I don't think you are hurting anything, but could be a problem if your car is left on and your radio is not on. Do what you want, and what works though. Just thought I could help
yeah my amp turns on with the radio the only problem was that the amp didnt turn on with the white striped wire but it turns on with the red wire.
BigPanch
BigPanch
Antioch, CA
BigPanch
slater
    Mar 22, 2025
slater
    Mar 22, 2025
